Potential iPhone 6 Plus (128GB version) recall
Rafagon
Dec 7, 2011
7,566
1,254
45
Miami, Florida
efuseakay
Nov 11, 2008
864
99
Not saying it can't happen to others, but my 128GB has been rock solid.
efuseakay
Nov 11, 2008
864
99
And one of the sources is Business Korea. Hmmmm... Doesn't Apple have a Korean competitor that often resorts to dirty tricks and outright misinformation? ;)
bballrob
Oct 11, 2009
1,921
476
Alaska
I'm so glad my Golden iPhone 6 Plus is only 64 GB. This would be devastating otherwise.
Sharunda
Jun 16, 2008
4,987
1,085
One Horse Town, New Jersey
Apple's decision to use triple-level cell (TLC) NAND flash storage instead of multi-level cell (MLC) NAND flash storage in order to save costs (shocker!) in its 128 GB iPhone 6 Plus may end up costing it a huge (by non-Apple standards, of course) amount of money.
Read on:
http://www.technobuffalo.com/2014/11/04/apple-may-have-a-huge-iphone-6-plus-recall-on-its-hands/
http://www.businesskorea.co.kr/arti...-iphone-6-raise-questions-about-controller-ic
Thanks for this info @Rafagon. If this is true and there is a recall Apple will do it with class. I can bring in my 128 6+ and they will give me a fixed version!
I'm not too concerned. I have had this reboot issue a few times. I figured it was because I had too many Apps open. When I close them then I don't have the issue. If I forget and leave a lot of them open I get the crash issue. This has happened to me twice. Since I close Apps I'm not using, I haven't had this issue in a while. Although I have had to do a hard reset a few times.
If there is a recall, I won't fret, I say thank you Apple for fixing the issue with a new 128GB iPhone 6+.
Rafagon
Dec 7, 2011
7,566
1,254
45
Miami, Florida
I've heard multiple folks on here say that you shouldn't force-quit your apps. Did a bit of searching now but didn't really find a specific post where this is mentioned. Word on the street is that you should let iOS manage apps (and therefore, RAM). If I happen upon the post I'm thinking of, I'll update this post with a link to it. But if having "too many" apps open is causing you to reboot, by all means... carry on :)
Anyhow, if a recall ends up happening, it sure won't hurt anyone to trade a month-old or two-month-old phone for a brand new one! Consider it a free battery replacement, if nothing else. And if you managed to get a scuff mark or two on your precious, you get a fresh start for free. :D
Part of me is actually hoping that a recall takes place. I won't gain anything personally (I have the 64GB model). But this could teach Apple a valuable lesson and maybe next year they won't try to save 10 or 15 cents on the cost of every unit they produce by choosing the cheaper alternative.
Rafagon
Dec 7, 2011
7,566
1,254
45
Miami, Florida
Why do you say that? Read what I wrote in the post immediately above. I see it as win-win. Apple wouldn't leave you without a phone until they have a new one to give you. At least, I hope they wouldn't.
28,365
5,507
And now I have Hippo's avatar. The forum locks up on me on nearly every post I make. I'm going to have to start using the app or another browser.
MrMike6by9
Nov 16, 2008
1,482
120
70
Maryland, USA
Interesting, 90+ percent of the time, I use the app vs. a browser here ... I was unaware of such an issue.
YMMV
iP5
Sep 7, 2010
2,964
136
Toronto
what I want to know is what's the buzz word for this? RAMgate, TLCgate, 128gate, bootgate?
Sent from my OnePlus One
