Power support no first layer?
Mar 23, 2009
26
In my haste I didn't apply the first skin layer. Do you think it makes any difference? Thanks
Mar 23, 2009
26
Power support screen protectors? There's only one "layer".
Thanks for reply. The kit comes with two screens with a plastic backing and one other layer (not a hard screen) on a white backing.
6,682
49
I think he's talking about the white "cleaner skin". It's a slightly tacky piece you use to clean any lint or debris from the screen before applying the actual screen protector.
To answer the OP, I believe it's optional. So long as your screen is clean when applying the protector, you should be fine.
mittenman
Jul 25, 2007
813
Nowhere, Mitten
Hmmm, mine didn't come with one of those.
Mar 23, 2009
26
OK gotta! Many thanks! BTW masking tap works fine also. At first you see some fuzziness but after a while it all disappears.
