Pre-Approval for speedy iPhone activation....
IPhone_Chica
Jun 14, 2007
77
So i noticed that on the iPhone activation video at Apple.com there is a credit check. This will prove to be a problem with some folks as they may require a deposit. In order to avoid this unwanted interruption you can simply go into your local corporate AT&T store and have them run your credit. This way you know if you need a deposit. This stays in the system for 30 days. While you are at the store ask them for the approval code. This code is what you can use when activating your iPhone instead of running your credit again. Hope this helps all. don't remember this being mentioned so thought I'd add it.:laugh2:
Bill A.
Jun 26, 2007
What if you're already a AT&T customer in good standing?
If you already have an account, do you still need a credit check?
Daywalker7
May 12, 2007
141
If you already have an account with AT&T/Cingular, you don't need to worry about a thing.
