Pre paid for iPhone
xsbx
Jan 5, 2008
40
Pay as you go, Is this possible? I searched on google and no sites really confirm it.
kylegod
Jan 1, 2008
581
Bethlehem, Pa
Att doesn't do it. Its probably possible if you unlock it. But then you won't get edge and will have to rely on wifi spots for your Internet which to me kills the iPhone Internet
xsbx
Jan 5, 2008
40
Gah thats terrible. Damnit ATT ugh
sportychick
Nov 18, 2007
50
Georgia
Just curious - why would you want to pay as you go? Wouldn't that cost more than the plan itself if it were an option? I mean for 20 bucks a month you get unlimited data + 200 text...
I guess I never understood why anyone would pay as they go if they use the phone on a regular basis. That is just my opinion...
xsbx
Jan 5, 2008
40
Well because I can't afford a plan at the moment. I just wanted some minutes for emergency calls and such but it doesn't matter now.
iCafe
Dec 11, 2007
1,877
www.wwtdd.com
best bet,
fail the credit check,
get pre paid
don't pay it after first month
now u have an unlocked iPhone
kylegod
Jan 1, 2008
581
Bethlehem, Pa
if you're that worried about bills why are you buying a 400 dollar phone if you can use it to its potential...
scandalex
Sep 16, 2007
771
Yes, you can do pay as you go. Because its an iPhone, the cheapest PAYG plan will cost you $70-75 per month.
I just helped a co-worker activate his iPhone and like myself, he didn't want to be locked into a 2-yr contract with AT&T.
Hook your iPhone up to itunes- activate- one of the screens (as you move forward) has plan options- The one you want to choose is called "Pick Your Plan."
Buy an iPhone. Now go to Radio Shack and get the cheapest GoPhone they have, it's about $20. Go home and activate the GoPhone via the instructions that come with that phone. Now unpack the iPhone and get ZiPhone and jailbreak and activate the iPhone. Now place the sim from the GoPhone into the iPhone and you have yourself an ultra cool iPhone Gophone. You can refill with cash when you can, refills can be $15, $25 and there are more amounts too. If your time runs out, you have a set amount of time which can be a month or two before the account will be cancelled for no funds. Just keep edge turned off on the iPhone, if you accidentally forget and use Safari, loading one page can cost several dollars.
Hope this helps!
depthnerd
Feb 16, 2008
1,280
You can get a standard phone with prepaid and just swap the sims with your iPhone one like I did.
True BUT if the iPhone he buys is 1.1.3 OTB, it won't accept a GoPhone sim in the iPhone. This is why I mentioned unlocking and activating the iPhone. It will then accept any sim.
