Preserved folder structure
lawrenjs
Oct 25, 2010
Will the folder structure of my apps be preserved if I upgrade to a newer iPhone?
Sent using iCafe app
jafundy
Jul 5, 2007
216
11
Mine did not when I converted to the iPhone 5. Sorry.
hifly
Aug 7, 2013
Most probably not. I think apps and app data backup depends entirely on the developers and what they choose their app iOS backup can contain. Did you backup your old iPhone via iCloud or via iTunes. I am not sure but iCloud backs up app data while iTunes backup does not.
Ledsteplin
Oct 29, 2013
4,849
1,002
66
Florence, AL
I don't think iCloud backs up game achievements or progress.
Sent on iPhone 5 using iCafe app
Ledsteplin
Oct 29, 2013
4,849
1,002
66
Florence, AL
It does. It's under Documents and Data.
The Verizon tech and the Apple tech told me wrong then. I was told I'd have to contact the Dev about it. The Apple tech messed me up when I upgraded to the 5. I had an odd situation though. But I could have done different than what he told me.
5,578
You don't need to involve Apple or Verizon. You simply backup the old phone before upgrading (you should be doing this daily anyway) and then restore from that backup when you get the new phone.
Ledsteplin
Oct 29, 2013
4,849
1,002
66
Florence, AL
I had changed my Apple ID a few days before I knew they would give me an early upgrade. I kept getting pop ups showing the old ID. So it wouldn't let me upgrade using the new ID. After I did it the tech's way, I found my problem. I had not changed the ID for FaceTime in settings. The Apple tech should have known to check that. It's one reason I'm here. To learn.
hifly
Aug 7, 2013
Indeed after a look at Apple's website, one can see that both iTunes and iCloud backup app data and documents (which should include game saves)
