Previously Deleted Apps and Customize
guest0320
Nov 11, 2007
728
A small problem, but..
When I jailbroke my iPhone, I added a lot of apps, which I subsequently deleted.
They are gone from the Installer, but when I go to Customize>Icon Display Order they are still there. If I activate the "eye" (the "be seen" command , I presume) they do not appear. If I scroll through Dock, they are there, but if I remove my finger when the icon is on the screen, they slide off the top of the screen
Not a major problem, but I would like to have a clean iPhone.
As always, thanks.
Dana
P.S. Also, I used iBrickr to remove the apps I loaded with it, and none of the apps which remain are associated with iBrickr.
guest0320
Nov 11, 2007
728
Thanks for your prompt response.
Sorry to be high maintenance, I have a damn good memory, but where (in Installer) is mobile finder?
Dana
