Printer app
superchaos
Feb 20, 2013
84
Just got a new canon printer that I believe has wifi.Looking for a good free app for sending text,PDF,pictures or what ever to it to print.
Sent using iCafe app
RoofMonkey
Jun 21, 2010
8,891
2,057
What model # is it? Not AirPrint capable is it?
28,407
5,539
You would like to print from your iPod/iPhone/iPad, correct? You don't need an iPhone app if your printer doesn't support AirPrint. You just need to install a program on your computer. This program runs in the background and makes the printer Air Print ready. You don't have to open the app before printing - it just has to installed. As long as the computer is on you will be able to print from your iPhones, etc. I use HandyPrint for Mac.
superchaos
Feb 20, 2013
84
Ok thanks.Maybe I'll install one for windows xp and try that.
