private number
Agent6
Sep 29, 2008
21
New Jersey
Hi, I just updated my 8g iPhone to a 2.2 version. I use to be able to make my phone number private. Since the update i can't do it anymore. The "off" is shaded grey under caller id and doesn't allow me to change it. Is there a way to hide my number and make it private?
Saverino
Jun 1, 2008
4,480
92
Burbank
Try resetting your phone.
I just tried and my phone still allows me to do this on 2.2.
If your phone still does this after the reset, I think you're having problems with AT&T and not the phone, because that menu is an AT&T feature...
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
I just checked it on my 2.2 firmware and the option to withhold the caller ID is available. I would do as suggested and try a reset and then possibly a restore.
ess_bee
Dec 16, 2008
152
UK
In the UK, you can type "141" before the number and you callers number would be witheld. I haven't tried it on an iPhone but the "141" does work on my Nokia.
If you live in the UK, give it a try...
Picazzo
Jan 21, 2008
2,808
Copenhagen, Denmark
Are you clean or jailbroken?
