Problem downloading updated software
yoyoma02
Sep 24, 2008
I am trying to download iOS 10.2 to fix some bugs in my apps via iTunes but I keep getting this error. It downloads for about a minute or two and then this error pops up:
"there was a problem downloading the software for the iPhone "iPhone". An unknown error occurred (9006). Make sure your networking setting are correct and your network connection is active, or try again later.
My Internet is working fine and I've been trying to fix this for a week. What can I do?
Ledsteplin
Oct 29, 2013
4,853
1,000
67
Florence, AL
Did you reboot your wifi modem/router? Did you Reset Network Settings?
Reset Network Settings Settings>General>Reset>Tap Reset Network Settings. You may need to enter your wifi passcode back in afterwards.
vongolashu
Mar 2, 2017
Just make sure no VPN, firewall or private network. I have seen most similar error appear with regulated networks or networks constantly having timeouts (use ping to make sure network is stable)
Lancetper
Mar 23, 2017
Every time I download some phone software, will display a page fault. i don't know what should i do ?
Kevin Barnes
Jul 23, 2019
19
try to get the iOS image without using iTunes. But be careful when you download files on the internet. Because apple doesn't support iOS 10 activities anymore.
