Problem: Main slider
siantslil23
Aug 29, 2007
99
can someone upload the bottombarbkgnlock.png.. from system/library/Frameworks/TelephonyUI.framework
michael180
Jun 14, 2007
1,249
Santa Cruz, CA
moderntimes.com
I've noticed as I download .png files via SSH, that I cannot view them. I get an error message saying that Photoshop cannot parse them?
Any suggestions?
CBRfanatic
Feb 28, 2008
302
Bronx
Any suggestions?
change your default viewer to preview if your on a mac, and im not sure for windows, but make it the default viewer for your system, aka whatever it was before photoshop. plus, you cannot view all png's can be viewed after download, it happens on a mac too, may i ask exactly which file you were trying to look at and ill see if i can pull it up?
michael180
Jun 14, 2007
1,249
Santa Cruz, CA
moderntimes.com
I'm on a Mac. I don't have the particular file I was trying to view at hand. But it happens every time I download a .png file vis SSH. It happens if I try to view the image in Photoshop, or with the viewer. The only time I experience this problem is with SSH.
CBRfanatic
Feb 28, 2008
302
Bronx
I'm on a Mac. I don't have the particular file I was trying to view at hand. But it happens every time I download a .png file vis SSH. It happens if I try to viewthe image in Photoshop, or with the viewer. The only time I experience this problem is with SSH.
what ftp client are you using? i use fugu without any problems. i don't know my way around to well with any of the others, but i know that will fugu there is an option for a secure download. i use that to save files to my desktop where i view them with viewer with no problem. trying to view the files within the ssh client never works for me. try fugu and post up your results, well get this sorted out.
you can download fugu HERE
michael180
Jun 14, 2007
1,249
Santa Cruz, CA
moderntimes.com
I use Cyberduck, which also has a secure download option. Your message had prompted me to look into the preferences, and I made some changes, I'll see if they work.
You've been helpful, thanks.
CBRfanatic
Feb 28, 2008
302
Bronx
anytime, keep me posted if it works or not, im going through the png's on my phone and making a list of what can and cant be viewed.
