Problem with customization
slayer666
Aug 13, 2009
122
I installed tap to unlock and fire battery theme the battery theme don't work and the tap to unlock takes away the writing "slide to unlock" how do I get any of these customizations to work? Any help would be great
Do you have a 4S on 5.1.1? If so, make sure your using a Tap to Unlock theme that is for retina devices and updated for 5.1.1. It sounds like the one you're using is t compatible.
  • Like
Reactions: slayer666
slayer666
Aug 13, 2009
122
Yeah I'm running 5.1.1 any unlock themes you recommend? And how can I get the battery theme to work? Thanks for you help
Same thing - you'll have to find a battery theme that has been updated for 5.1.1 or update it yourself. Apple changes the file names with many of the firmware updates, and that makes the old themes not work until they are updated.
I just tried 'Tap to Unlock Retina Applestyle', but it requires a very minimal slide to activate. It worked fine on 5.0.1. I'll let you know if I find one that's working on 5.1.1.
  • Like
You'd have to get into the file system with iFile, DiskAid or SSH, find the new file names, and then update the themes. Which battery theme are you trying to get to work?
  • Like
I got the fire battery file names changed and it's working now, but (as you can see from the screenshot below) the images will need to be doubled in size. I'm at work right now, but I'll do that in Photoshop in the morning. PM me your email and I'll send you the zipped theme when I'm done.
Alright, I got it updated for 5.1.1 and emailed it to you. Just extract the file, put the folder in your Themes folder on the iPhone, and then apply through WinterBoard. Let me know if you have any questions.
