Problem with Cydia
Oct 5, 2009
23
I had add the wrong repo add to cydia. Now I faces the problem of cydia keep updating and prompt that the error is bad URL. So how do I solve this problem. Try to search for the wrong repo, it cannot be found.
Help please
Oct 5, 2009
23
Go into Cydia and go to Manage > Sources and delete the source from there.
I had tried looking for the source but it's not in the source menu. Is there any way to resolve the problem?
I keyed http:// d.mobilecinema.com I forget to key in the i infront of mobilecinema so cydia keep updating and prompt me of the bad URL and error. What should do?:mad:
Corny
Dec 29, 2009
21
I have jailbroken 1 month old iPhone 3GS on PAYG Orange, couple of probs I cant view youtube videos on it and I cant load Cydia as of this morning? Anyone had same probs or can help?
Thanks in advance
Corny
Newcastle upon Tyne
Corny
Dec 29, 2009
21
sorry to sound like a moron! how do i know if "If your YouTube app is in a folderof some type such as categories" and how do I remove it?
Craig
Jan 16, 2009
3,230
58
Mississippi
Craig, never mind, if you can see it on one of your pages then it's not in a folder. I have folders which look like an application's icon but when you tap on a folder it opens to show up to 16 apps. So I can put a lot of apps on one page and I don't have to keep swiping through pages to get to a certain app. I hope this explains it for you.
Corny
Dec 29, 2009
21
Morning all,
3.1.2 software jailbroken iPhone 3GS cant get Cydia to load categories etc keeps saying error :Database Encountered a section with no Package:header, tried uninstalling it, and rejailbreaking to no avail? help! I don't knw / understand the SSH carry on :)
Thanks in advance
Craig
07875826453
Krunk83
Jun 28, 2008
4,605
Well, what do you mean by uninstalling Cydia and rejailbreaking. Once Cydia is installed, you cannot uninstall it. You would have to restore to new and start all over again. Before you try that though, give it a few days. This has happened to me before and has corrected itself after two or three days of error messages like the one you are receiving. If it doesn't correct itself in a few days I would recommend a restore and jailbreaking again.
Corny
Dec 29, 2009
21
Gotcha, I used cydelete and I did think it hadnt gone, I then reinstalled it and same thing happening, I will do as you say and wait for few days rather than lose everything and start again! I read somewhere online that it may have been that Icy was conflicting with it? All it mean si suppose is that I am stuck with the themes and ringtones I have, Thanks for speedy reply.
Craig
Krunk83
Jun 28, 2008
4,605
You have Icy? The current blackra1n jailbreak doesn't even offer that up because it's so buggy. I would suggest not using that. Also, when installing Cydia and/or Rock, do them one at a time.
besweeet
Jun 7, 2009
968
26
San Antonio, TX
briansweet.me
A lot of people solved this problem by going into /var/lib/apt/lists, and deleting everything except for the partial folder and the file called 'lock'. But since you don't know how to SSH or browse the file system, you could try waiting it out, or try jailbreaking with redsn0w (instead of blackra1n if that's what you used).
aaronsiphone
Dec 28, 2007
297
im having some issues with cydia, I added a couple of rogue repos yesterday and ever since all cydia does is load packages and no thin happens. I cant seem to delete this repos as they've gone under phone repos, not user added meaning I cant delete, what should I do. im not keen on a restore!
besweeet
Jun 7, 2009
968
26
San Antonio, TX
briansweet.me
You can manually navigate to /etc/apt/sources.list.d/ and edit out the sources in cydia.list, or delete the appropriate .list file.
Then go to /var/lib/apt/lists/ and delete everything but the partial folder, and the lock file.
Dec 15, 2008
5,386
340
27
Pensacola, FL
I was finally able to see things in iFile in /var/lib/apt/lists to delete everything but the partial folder, but I still have been getting the 'Encountered a section with no Package: header. Any suggestions? If you want me to start a new thread, I will. @Europa @Napoleon PhoneApart
I may have just found out which repo it is. HMM...I thought I did but now the error still shows when refreshing Cydia.
