Problem with firmware?
Hookem99
Feb 12, 2008
199
Deep in the heart of Texas
I am not really sure where the issue lies, but here is whats happening;
Bought 2 new iPhones 2.5 weeks ago.
Mine came with 1.1.3 and have since had not a single problem.
My wife's came with 1.1.2. As soon as we activated it, it tried to upgrade to 1.1.3. After getting several error messages(could not update due to unknown problem) it finally upgraded. After some light use, she wanted a couple ring tones. I made them(2), paid for them and tried to install them. After syncing, both tones, in iTunes it showed them both there. On the phone, it showed tone 1 twice. Go into iTunes and delete the tone it shows on the phone, and then, on the phone tone 2 is the only one there. (and vice vera) After several attempts to solve this, I did a restore and that seemed to solve the issue.
Yesterday, I install 1.1.4. Not a single issue on my phone, but on my wifes, Cannot update due to an unknown error. I took 3 attempts to get it installed.
Last night I made her more ring tones, and tried to sync them. Same issue. The two original tone are there, but the three new ones, which show correct in device ring tone folder in iTunes, are all listed as the same tone. Delete that tone from the list, it shows the next one twice.
Example(on device):
Original tone 1
Original tone 2
New tone 1
New tone 1
New tone 1
Example (in device RT folder in iTunes)
Original tone 1
Original tone 2
New tone 1
New tone 2
New tone 3
Because of the issue installing both firmware updates, I would think the issue is there, but who knows. Also, shortly after the 1.1.4 update finally installed, iTunes started locking up when I plug in the iPhone.
A call to Apple care, only brought about another restore, and the same issue!
Sorry for the long post, and I hope it makes sense. Thanks in advance.
