Problem with iPhone weather
Druhil2003
Dec 4, 2007
Hey Everyone,
I just got a new iPhone due my other one going into a coma and dying but I can't seem to get the weather widget to load on the new phone. When I tap weather, the screen switches over to the weather application screen but everyithing is blank and after about 2 secs it just goes back to the home menu. Anyone have any ideas or does it look like I'm heading back to Apple for iPhone number 3....If I am it's gonna suck cause there goes 2 perfectly good screen protectors! :mad:
Thanks in advance!
First make sure that you're in good range of a Wi-Fi spot or you have a good EDGE signal.
Then try a Restore.
If that doesn't work, go to Apple.
- John
Chris716
Nov 29, 2007
807
IL
try a restore first if that doest work go to Apple
Druhil2003
Dec 4, 2007
Thanks guys,
First thing i did was try the restore and that didn't work so I made an appointment and the Apple store. Oh well.
Thanks again.
Dawgfan
Jul 27, 2007
347
Atlanta, GA
Very, very weird.
Before going to the store I might try deleting all the cities and starting over as well.
Also... check out i.wund.com It rocks.
gijohn
Jul 22, 2007
172
67
Did you try a hard reset? ...... (Home button and sleep/wake button til you see the Apple logo)
Druhil2003
Dec 4, 2007
Tried the hard reset first and no dice and I can't delete the cities because I can't even get into the program in the first place:(.
Thanks everyone for your suggestions---I have an appointment in about an hour.
