Problem with JB 7.0.2 sprint boot loop!
Pirkez89
Apr 5, 2014
9
Hi guys, I have ios 7.0.2
I tried jb with evasion tool 1.0.2, I didn't make backup, phone is bricked.
Can I manually install 7.0.2 or 7.0.4 update to solve that peoblem? Or I need to update to 7.1, but I don't know is there any r or x sim which will unlock the network.
Jun 19, 2007
33,478
4,542
Upper Marlboro, MD
If you have an iPhone 5, you're out of luck as far as restoring to a lower firmware revision. If you end up having to restore, you'll have to restore to iOS 7.1.
When you last updated your iOS firmware, did you update it OTA (over-the-air)? If so, the chances of a successful jailbreak are very slim.
Pirkez89
Apr 5, 2014
9
I was read for some thread on the Internet, I can update Ipsw via iTunes pressing shift button and chose that Ipsw which I downloaded before. I don't know is updated via air or PC, becouse I bought it like that, but to sad girl so i think ti was air probably.
Is there any other chance to put it back alive in system which is now.. 7.0.2.. Or do you know which r or x sim to use for 7.1? Is there some other problems with 7.1.. 3G.... Sms..
Pirkez89
Apr 5, 2014
9
:-( I have another iPhone 5 7.0.4... Maybe it is stupid... But, can I make backup of that phone and to use like restore for the another 7.0.2?
Something about r-sim?
28,365
5,507
If there is any possibility that you will want to jailbreak in the future, even if a jailbreak doesn't exist at the time, do not use over the air updates. Do full iTunes updates instead. OTA updates cause the problem you experienced. And if the latest firmware version is non-jailbreakable like 7.1, there is no way to get the jailbreak running on the phone because it forces a restore to the current firmware.
