Problems with App Icons
seraphkz
Sep 3, 2009
My AIM icon appears to be Palringo's.
This happens to some of my other apps too. Does anyone know why this occurs?
evolution83
Mar 2, 2009
3,322
43
California
It's a bug in the OS 3.0 software. I've found that uninstalling the apps through iTunes, rebooting your phone then reinstalling the apps again in iTunes helps.
seraphkz
Sep 3, 2009
thanks for the reply. I don't think I'll go through the trouble just to change the icon. I mean after all it still works fine.
evolution83
Mar 2, 2009
3,322
43
California
It may work fine, but normally if you don't fix it, newly installed apps might face the same issue once they're installed or you reboot the device.
Andrew_H
Sep 18, 2009
im having the same problem, after I rebooted my iPhone all the apps look f***** up. now I know how to fix it thanks
