Problems with Apps Crashing
pickchic
Sep 15, 2008
Cleveland, OH
I've read that lots of people are having the same problem, but have seen no solutions.
I downloaded several apps. Everything was working fine. I did an update and now none of my apps will open. Even new ones that I download.
I read that Steve Jobs was going to have a fix for this in Sept. Hmm. Month is 1/2 over, am I missing it? Anyone have a solution that works?
Thanks much!
psylichon
Oct 31, 2007
16,591
751
41
Philly
I think so, that was the last update?
If by "last update" you mean the one that came out on Friday, then yes, that one. Just have iTunes check to make sure you have the latest version.
For the most part, apps should not be crashing in 2.1 like they did in 2.0
