Problems with iTunes ringtones
Sep 9, 2007
9
I can;t get it to sync but one of my ringtones that i made in iTunes it worked fine before today now it will only sync one of the ringtones, anyone know what is wrong or should i go back to iPhoneringtonemaker.
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Are you at 1.1.2 ? How did you make your other ringtone that works. Need more info to help you. There have been many treads on this subjct.
Sep 9, 2007
9
I made through the convert a song already in iTunes and then change the exstension way.
KNK
Jul 22, 2007
2,391
Stevenson Ranch
yes 1.1.2 is what i am running also.
If you open iTunes, and open the ringtone folder, is the 2 ringtones you made there?
If you connect your iPhone to iTunes, in the summary under ringtones are both checked.
Sep 9, 2007
9
Yes i have about ten ringtones i made and one that i bought from iTunes they are all checked, but only one syncs and it's not even the one i bought from iTunes
KNK
Jul 22, 2007
2,391
Stevenson Ranch
I am going to PM you to send me a couple of those ringtones to check them.
Sep 9, 2007
9
I'm gonna try resetting my computer, first that's the only thing i haven't tried yet. I'll let you know how it turns out.
Sep 9, 2007
9
yes it is still not syncing my iTunes ringtones only my iPhoneringtonemaker ones. I can't under stand what's going on.
bean22
Dec 13, 2007
65
Once you use iPhoneringtonemaker to put ringtones on your phone, you can't sync or use the ones you purchased from iTunes. If you look on the IPRM website,(click on iPhone/iTunes Supported then click on key things to note) they warn people about that.
