Problems with playing music
Binky
Aug 6, 2014
I converted some of my music purchased from iTunes store to ringtones. The problem is that all the music in my Music folder is now playing for just the 30 seconds which is the duration of the ringtones. I can see the entire length of the songs but they are only playing the selected portions on the ringtones. How do I make my music play the whole song in my Music folder?
Ledsteplin
Oct 29, 2013
4,841
997
65
Florence, AL
I saw someone else with that issue recently. Is it all your music, or just the songs converted to ringtones? How many songs do you have? You can try deleting the affected songs. Then do a hard reset. Hold the top power/sleep button and the home button at the same time until the Apple logo appears, then release. Then download the songs back. If that doesn't work, you'll need to straighten it out in iTunes on your computer.
28,437
5,560
Open iTunes on your computer and uncheck the box for syncing music. Sync to remove the music, recheck the box and then sync again. That should put the full-length music back on.
