proximity covered
mickey35
Sep 5, 2007
54
I was given a skin for my 3G, it is a "FUZE" cover.
However it seems to block the proximity reader to the extent that when on a call the phone does not go dark and my ear hits "mute" or something else and I lose the call.
Ques: where exactly is the proximity dot? Maybe i can cut a hole in the cover.
Quake97
Jul 10, 2007
522
Philly Burbs
You can see them under the right angle. Try tilting you're phone away from you under good light and look to the left of the ear piece. There are two in the vertical position and one further to the edge of the phone.
Joe
Emerica
Feb 5, 2009
82
The case shouldn't cover those.
mickey35
Sep 5, 2007
54
Joe
Thanks,
Are all three part of the proximity detection? I.e., should I try to uncover all three or just one?
mickey35
Sep 5, 2007
54
Then it's not for a 3G, it's for an original iPhone.....
That is the conclusion I reached as well.
I cut off some and it works fine now. It was free anyway.
BTW, thanks.
