Purchased a tone with bell next to it, bell doesn't appear in my library?
danielfillmore
Jul 4, 2007
132
i am making a ringtone for the first time. i purchased a song with a bell next to it, but in my library it does not have a bell. why is this and what can i do about it? thanks.
Marianne
2,326
29
Massachusetts
marianneschultz.com
the ringtone bell column may not be selected in your view options. i'm not sure if the menus are different on a pc in iTunes, but on my mac, i go to View, then select View Options and i get a list of column headers to choose from. make sure the Ringtone box is checked while you're viewing your Purchased iTunes music. once the bell shows up, you just double-click on it to create a ringtone.
