pwnage 2.0.3.1 + restore from backup
sl0ppyshat
Oct 2, 2007
178
I was wondering after jailbreaking using pwnage can i update from a backup or do i have to restore as new phone?
mletang
Jan 23, 2008
120
NYC
www.NYCpetforum.com
restore as new. even after your pwned and u update to an updated custom firmware u need to setup as new. restoring from a backup will cause problems.
termleech
Sep 7, 2007
1,154
McPherson, KS
I jailbroke and used a backup and everything has worked great so far. What issues have you noticed using backups?
sl0ppyshat
Oct 2, 2007
178
Thanks Termleech, I have been receiving mixed answers about this but I guess ill try using the backup first and if it doesn't work right then I will setup as a new phone
THEHNIC
Feb 11, 2008
97
CA
If you have problems with the backup, just use BossPrefs Fix User dir Permissions fix and everything will work just fine.
