pwnwage tool
__DorkSterr
Jan 20, 2008
90
what happened to it? i heard it got shutdown is it true?
That was April Fools. Pwnage should be available sometime next week.
- John
THEHNIC
Feb 11, 2008
97
CA
I was but I did a restore and lost them. So I had to reinstall them again but that did not take to long.
Were you on a jailbroken phone before? If so what about any existing apps and themes you had?
michael180
Jun 14, 2007
1,249
Santa Cruz, CA
moderntimes.com
I don't know much about Pwnage, but I guess you have to do a restore? I'm jailbroken, and everything works so well, I just hate to start over. And I'm not sure of the upside of Pwnage.
Hondamaker
May 14, 2007
9,946
671
56
Fairborn, Ohio
I'm not sure what it does, either. I have it on my mac now, but I just looked at it and said, wtf am I supposed to do with this.
Jhors2
Nov 11, 2007
239
You can immediately "PWN" new firmware which basically allows you to add some files on it that will jailbreak, unlock, and activate the iPhone or any one of the three when you go to upgrade the firmware. You do have to restore the firmware onto the phone as opposed to a simple upgrade, but its supposed to be a lot easier than upgrading it, then downloading a jailbreaking app like ZiPhone or something and doing that.
themanofthedark
Jan 5, 2008
2,674
26
Boston
also, you can make it so you restore and wind up straight away with a jailbreak and an unlock and a hactivation...
pwnage>ZiPhone.
