Query about Podcast
you2
Nov 22, 2006
61
How do i make certain episodes of podcasts present on my iTunes?
I want to keep only a few episodes because it takes up a lot of space(I have 40 or so episoodes of channel frederator that take up a gig of space) But i still want them kept on iTunes. I assumed this is what the boxes were for(that you can check and uncheck) but that didn't work(what is that function anyway?)
Any help would be nice
Dec 15, 2006
I think the check box function is when you are listening to songs and you don't want the next song to play you uncheck it & it will skip that song.
If you want to sync just the checked songs etc you need to plug your ipod into your computer then go to the summary, it should say 'Only sync checked items' or something :)
