Question About 1.1.1
surjit
Nov 3, 2007
Hey guys...
I'm new to this site.. I have few queations.... My iPhone's firmware is 1.1.1, is it possible that i upgrade it and still be able to use my iPhone without activation. I'm a AT&T customer.
My second question is how to get my visual voicemail working?
thanks in advance....
skiz420
Jul 28, 2007
371
Boston
yes you can.... if you look in the modifications area this has been gone over thousands of times already... if you have already unlocked your phone then you have to "revirginize" it first to fix the baseband on the modem... if you just unlocked, activated and installed 3rd party apps then just update and follow the instructions in the modifications area or on www.hacktheiPhone.com... that will get you back to a jailbroken, activated 1.1.1 phone.... as far as the VVM if when you hit voicemail it calls the number insted of showing the voice mails dial *3 on your phone and it should call the voice mail then hang up and go to the voicemail tab again and put in your password... then your all set.... please look around for the answers insted of just creating a new post next time.... Thanks
petalmom
Jun 30, 2007
494
Hey guys...
Visual voicemail is specific to AT&T and will only work with a phone activated with AT&T service.
