Question about after jailbreaking...
canecop
Oct 21, 2007
85
I just followed some guys directions on Youtube and used ziPhone to "jailbreak" my phone I think. I now have the installer application on my phone but my question is am I limited to what that installer has as far as applications are concerned or can I install other programs that people talk about on this forum. If so, how? Thanks in advance.
24trepid
Jan 13, 2008
502
Before you add an app, just do a little research.
Cause they're some bad ones out there.
In order to get a wider selection, you need to add Sources. Sources are websites where the applications are downloaded from. To add a Source, click on the 'Sources' button in Installer, located in the bottom right corner. Now in the top right, tap Edit. Then in the top left, tap Add. A pop-up box will appear with a keyboard. Here you type in the URL of your source, such as http://ride4.org/shai.xml.
Also, check out this thread as it lists dangerous things in Installer you should be wary of.
- John
