Question About iLiberty+
ChArLiE713
Jul 3, 2007
149
What do I check for options before I start to jailbreak it? I have 1.1.4 if that matters. So far I have checked Jailbreak, what else should I check?
THEHNIC
Feb 11, 2008
97
CA
Bump...someone please help me
Well if you need it unlocked then that box, and I would also check the youtube fix,Setup Installer,Activate if you are not on AT&T already.
I checked the box to downgrade my bootloader but that is up to you.
ChArLiE713
Jul 3, 2007
149
alright thanks for the response...what is the bootloader for?
ChArLiE713
Jul 3, 2007
149
Hey, I just jailbreaked it and there is no Installer. Was I supposed to check Cydia? Also, I have no signal.
Jul 18, 2007
21
30
East Palmdale, California
Is cydia worth installing or should I just use iliberty to jailbreak the phone then get a copy of installer on it?
Anyone who is willing to give some info on this and shed light I would appreciate it, I used to use ziPhone but now i read bashing and everyone claims iliberty and it are the same thing almost just one is more trusted besides the other.
Well please shed some light.
ChArLiE713
Jul 3, 2007
149
How do I get Installer on my phone. It's not there.
ChArLiE713
Jul 3, 2007
149
Why shouldn't I use Cydia? Can I still install Cydia even if I've jailbreaked already? Or do I have to restore and do it all over again?
Jul 18, 2007
21
30
You can install cydia after it's jailbroken, cydia can be installed and some just say cydia doesn't work very well with some apps, I haven't researched much.
ChArLiE713
Jul 3, 2007
149
What do I do to add it then? Do i check Cydia and nothing else or should I keep everything the way it was checked and just add Cydia and press "Go for It"
