Question About iPod Classic
topcat84
Jun 28, 2007
294
I would like to put my whole CD collection on my new Classic iPod (160GB). I've never owned an iPod before so I'm relying on the expertise of you iPod owners out there. My question is this.....After I rip my CDs into iTunes and sync them onto my iPod, do I have to leave those previously ripped CDs in my iTunes library when I sync new music, or can I delete those CDs and add others ? I know with my iPhone, if I sync music to it and then delete them, the next time I sync new music to it, it deletes the music I've deleted for iTunes. Please help. Thanks in advance.
420greg
Jun 26, 2007
845
Orlando, Florida
It works just like your iPhone about deleting music.
But you can put an ipod in 'manually mode' to manage the music by hand like if was on an external hard drive. It will not auto sync in this mode. You have to add and remove files manually.
topcat84
Jun 28, 2007
294
Thanks go out to 420greg. Now, can you or someone else walk me through the step by step procedure of adding my CDs to the iPod Classic and then deleting the CD from the hard drive w/o it removing it from my iPod ? Thanks in advance.
420greg
Jun 26, 2007
845
Orlando, Florida
Go to iTunes preferences and click Advanced | Importing
set On CD insert to Import CD
Check Auto track name and Create Files track number
Click OK.
Hook up the ipod and click the summary tab. Choose Manually Manage Music.
Now just move your music files from the computer to the ipod. Just like you were coping files from one folder to the other in windows explorer. iTunes is laid out the same way. Select the song files from you music list and drag them to the ipod icon on the left and drop them on to the device.
