Question about jailbreaking
madman555
Jul 18, 2007
Hi all,
So I'm about to jailbreak my 3G phone but had a question first. Once Apple releases a new firmware, will I lose everything I've customized on my jailbroken phone (apps, settings)? Thanks!
psylichon
Oct 31, 2007
16,591
751
41
Philly
Yes, pretty much. When restoring from a jailbreak, it is always advisable to set it up in iTunes as a new device (and do not restore from your backup). A jailbreak can leave residual files that can cause problems down the road... especially if you rejailbreak.
So you must find external programs to sync your data. You can set these up through iTunes to backup your contacts, bookmarks, calendar, mail, etc. I use Nuevasync.com to sync my contacts and calendar, and Gmail doesn't need backing up really, so I'm set. You will lose notes and SMS unless you back them up via other means.
Check out Chronus on Cydia once you jailbreak. It will allow you to backup and email certain files to yourself than you can then use as a backup if you ever restore/rejailbreak.
