Question about location reminder on iPhone 4
jareknyc
Aug 27, 2007
715
NYC
Hey guys If I ask my iPhone to remind to me call my wife after work, is the gps location arrow i see by that clock on the top, is that draining battery or not really? I have a feeling it's using gps all the time to see if I left location... Am I right?
Michael Baturin
Jul 11, 2007
1,751
244
34
South Jersey
Good question - and something I wanted to ask as well. Since the battery does seem to drain rather fast - I am wondering how the phone has a constant awareness of your location without using battery
Booyow1204
Jul 14, 2010
595
40
Las Vegas
It doesn't know w/out using battery, location services will drain our battery, all of them aren't always needed, but there always will be drain just how much is the question.
dturner
Dec 15, 2007
5,725
Louisville, Ky.
It is using battery. That's why I don't think I'll ever use that function. If you did a reminder in the morning at work, you may not have a battery when you leave. 
Sent from my iPad using iCafe app
fury
Oct 23, 2007
2,274
236
35
Louisville, KY
I think it uses cell tower triangulation and wifi hotspot location instead of GPS for the location-based reminders. I told it to remind me to clean my damn kitchen when I get home...and I got the beep once I got to within a couple miles from my home. That way, it doesn't use much more battery than the phone uses in normal operation. Since it has to connect to cell towers anyway, it's only a slight blip on the radar to ask for the location of those towers when it jumps over to another one.
It's hard to make a repeatable test out of it to determine exactly how much, though, because the power it uses is never exactly the same even in the same route and same usage every day.
Mhlewis
Oct 16, 2011
Not sure if my question is on topic for this forum, but it is about the reminder by location feature. As far as I can tell you can't actually enter an address, you can only choose the addresses of your contacts. Is this correct or am I missing something?
PDACPA
Jan 16, 2008
542
I cannot find how to set the "remind me" and "geofence" in the Reminders app. There is nothing in location services to say "turn on" and I cannot find any option to select a "location" in the reminders app.
Does it require iCloud to work (have not completed my transfer of Mobile Me to iCloud) or is there a feature in setting that I have not found?
PDACPA
Jan 16, 2008
542
Scratch that...found it online. For those of you who do not know, once the reminder is created and done...hit the gray arrow to the right of the reminder in the reminder list and then it will open a window with the reminder title and the next option is remind me....hit the right arrow AGAIN and you get the location option.
