Question about map application
BigCiX
Jul 11, 2008
1,445
Bakersfield, CA
I'm going to Pismo Beach this weekend and i wanna use the maps app on the iPhone. Problem is that it's giving me the long way. Is there any way to make it go a different route?
aenti
Jul 8, 2008
1,155
Maryland
Nope. The Maps does not offer alternative routes unfortunately .
stevetim
Jul 20, 2007
606
You can change your starting point with the pin. Drop a new pin, drag it and have it start closer to your intended route. Then, tap on the pin and get "directions from here" to your destination. It's not EXACTLY what you want, but it will do the trick. The only thing is, you have to navigate or get directions to the new pin that you dropped first.
But you can also make a route to the from your current GPS position to the dropped pin so it actually works pretty good. If you use this route frequently, bookmark the new dropped pin and use it as a waypoint.
Good luck.
nobopyon
Jul 11, 2008
393
Dallas, TX
Good luck.
That is a great trick!
