Question about ringtone hack.
iigreatoneii
Jul 3, 2007
234
Orange County, CA
Ok, so I've been seeing a lot of people talking about hacking their iPhone and adding custom ringtones. I was just wondering, if you do that, does iTunes still update correctly when newer version are availale? It seems like you're disabling the program form updating based on the tutorials for it. Just curious, it just seemed like the iTunes program may operate slightly differently than it would if you didn't adjust the settings.
jonnyp
Jul 11, 2007
I think I'll just wait for Apple to come up with an update so we can just put our own custom ringtone...it won't be too long..I hope. :)
RomeoSto
Jul 6, 2007
59
Chicago IL
my iTunes wasn't affected by the hack, as long as u do the steps correctly u should be fine. Worst case scenario just do a restore but make sure u sync your info before u do anything.
chris07
Jun 30, 2007
145
nope dosent affect it and will still install updates but the only problem i heard is that when the updates come u loose all your hacks ringtones,servicelogo,etc..
