Question about videos on your iPhone
iigreatoneii
Jul 3, 2007
234
Orange County, CA
Hey guys,
I know this has already been talked about, but I can't find the thread on it....anyways, when I play certain movies/tv shows that I converted, it has green lines on one side of the phone. What is causing this? It's not all videos, only certain ones, could it be the video codec or something?
daviddogma
Jul 5, 2007
101
Hey guys,
I believe, and don't quote me on this, but you have to take the plastic off the screen of your iPhone. If you have done this you may want to get your hearing checked first. These solutions have worked for many in this forum :cool:
iigreatoneii
Jul 3, 2007
234
Orange County, CA
haha
You're pathetic. Anyways, as if I have to prove anything to you...Yes I own an iPhone, picked it up today at Apple in Mission Viejo, CA. And no thanks to you, I solved the problem. Thanks for nothing.
daviddogma
Jul 5, 2007
101
David, how old are you? All your posts are very childish. If you're a grown ass man, then you are very pathetic.
Childish I agree, but I ain't the only one. I was just trying to fit in with all the obvious answers and name calling. Why is it so important that you know my age? Are you a catholic priest?
tamakin
Jun 30, 2007
404
You were a total dick to this guy that started this thread. Chill out bro.
daviddogma
Jul 5, 2007
101
I guess I just thought this was the way you guys did things on this forum as any question I have asked looked for earnestly was responded with things like: "You should get the ear wax out of your head." or "Not to be rude, but did you take the plastic off the cover." I agree I am being passive aggressive, but I was hoping someone would read my answers and realize these answers are absurd.
Ace4261991
Jun 18, 2007
530
iv noticed that in one of my videos before what did you do to fix it?
iigreatoneii
Jul 3, 2007
234
Orange County, CA
If you have problems with green lines on the right side of videos after you sync them to your iPhone, try putting them in the H.624 file format. That worked for me, some will work in MPEG-4 and some will not.
I'm using the H.264 QVGA 768kbps Stereo/128 kbps Advanced profile to convert the videos I was having the green lines issue with and they all work now.
Hope this helps.
qlock
Jul 2, 2007
Definitely encode in h.264 for best quality/size. this will solve that issue.
