Question for traveling abroad
May 6, 2007
995
United States
Hey guys,
I just had a quick question. I'm going abroad soon and I have called AT&T a few times, only to receive a whole lot of frustration.
I am fairly positive about the answer to this, but I was just going to check: If I'm using WiFi abroad, will I be charged for data? I assume I won't be, but I won't be buying an international plan and I don't want outrageous bills.
I know threads have been posted on this before, but they were from a while back so I figured it would be a trouble to bring them back up.
Thanks!
Marianne
2,326
29
Massachusetts
marianneschultz.com
If you're using Wi-Fi only, you will not be charged for data. To make sure your iPhone won't sneak by Wi-Fi and use the network instead, you should turn on Airplane Mode and then turn on Wi-Fi separately. AT&T, nor any carrier to my knowledge, has the ability to track your data usage when you're on Wi-Fi only and not on a cellular network. In Airplane mode with Wi-Fi on, your cellular radio is completely off and AT&T will not know what data you're using, much less charge you for it.
You should also check out AT&T's global roaming page specifically for the iPhone here, if you haven't already.
May 6, 2007
995
United States
Thanks for the quick and complete reply! I'll check it out and do what you suggested. Have a good one.
