Question regarding iOS 7 notification center
coop1701
Jun 30, 2007
899
114
43
After the update yesterday, my Notification Center is now Black instead of blurred. I thought I had found a toggle for that on a previous build. But I have had no luck in finding it.
Can someone tell me where it went?
iphonewarrior
13,847
701
I don't believe there is an option to change the background of Notification Center in iOS 7 beta 3. If there is I can't find it either.
coop1701
Jun 30, 2007
899
114
43
Mine was blurred before the Update. I even changed to different wallpapers thinking maybe something I had done made it go to black. You can't even see the X's to dismiss a notification with it being all black.
coop1701
Jun 30, 2007
899
114
43
Found it iPhonewarrior ...
Under accessibility, if you turn off Increase Contrast. It will go back to the Blurred/Transparent background. Hope that helps.
