Question regarding the "restore" feature on iTunes
mrk
Oct 2, 2007
21
i just updated my firmware to 1.1.4, and now want to jailbreak it... but it says i must restore then update.... well, im already updated to 1.1.4, so i guess i just need to restore... my question is, will restore delete all my mp3's on my iPhone? i believe when you sync, it only saves the songs that are on your iTunes library... i have nothing in my iTunes library, i added my 1000+ songs by manually dragging and dropping in from my many external HD's that took hours to do... so i want to make sure what im doing when i press that restore button.. please help
mrk
Oct 2, 2007
21
do i really have to restore before doing the jailbreak? basicly i had a JB 1.1.1, then updated to 1.1.4, it seems like a fresh start, since all the apps are now gone
todesto
Sep 30, 2007
59
My question is similar to this topic so i am adding it on....;)
I know you are going to lose everything on your iPhone once you press restore, then is there a way to save the camera roll pix by putting it back to camera roll?
Swagger
Jul 9, 2007
2,076
Fort Lauderdale, Florida
web.me.com
You can download your photo's to a photo program on your computer or your my picture folder, then put them back on after restoring. Also make sure you Back Up your iPhone, before restoring to save all your settings, notes, contacts and etc...M
Jul 6, 2007
1,832
25
Marietta, GA
about.me
yah it will delete everything you have on your iPhone and then when you restore it puts back all the data such as text messages and phone calls and internet history. for media you have to sync it back yourself from your iTunes library
todesto
Sep 30, 2007
59
after restoring after back up, you are saying it gives text message data back as well as other data backed up in iTunes? what about pix taken with camera (camera roll)? does it come back to camera roll?
Keagle
Feb 2, 2008
182
I can access my camera roll pics through Windows Explorer - so I just drag and drop them out. And then in again.
todesto
Sep 30, 2007
59
Just want to make sure...
1. So when you back up your phone through itune, copy the camera roll pix through Windows Explorer to some folder on HDD
2. restore with 1.1.4
3. JB with ziPhone
4. resync with itune, then
you get your data INCLUDING SMS DATA?
also, copy the pix of the camera roll from the folder you used to copy back to iPhone using Camera roll, then the pix shows up in Camera Roll?
Can anybody confirm this? I would like to try 1.1.4 since consensus is 1.1.4 has LOUDER volume.;)
