Questions about backups to computer
rainbow_dog
Apr 13, 2012
For extra peace of mind, I use iTunes to back up my phone's data to my desktop.
Where are these files?
Can I view their contents directly?
How could I use them if something happened to my phone?
Kriss
Jun 8, 2008
598
121
43
Cape Cod
voyager01.deviantart.com
Well, if you have a Mac... They're in Library/Application Support/MobileSync/Backup. They're not really user accessible but you can use third party software to view/modify them. If your phone had to be replaced or you restored it, you can restore from backup in iTunes. Sorry I couldn't tell you more. A Google search will give you some good information.
Ohmster
Jan 26, 2008
533
21
SoCal
No need for third party utilities. Since at least Lion, to get to the Library: In Finder go to the 'Go' tab whilst holding down the Option Key. Select Library and a new Window will open for that Folder.
jimmerlink
Oct 9, 2012
9
1. Connect the iPhone to the computer with a USB cable.
2. Open iTunes.
3. Click on your iPhone under DEVICES in the left menu.
4. Make sure the Summary tab at the top of iTunes is selected.
5. Under the Backup section, check the "Back up to this computer" radio button.
6. Click the Sync button.
You can also backup to iCloud to keep a copy of your iPhone data on Apple's servers.
rainbow_dog
Apr 13, 2012
I guess I was little unclear. Let's make it more concrete and take a disaster scenario I'd like to be prepared for*:
  • The iPhone is stolen and for some reason I can't access icloud either.
  • I don't have time to get a new phone. (and who knows, maybe I want to shop a non-Apple device. Sacrilege, I know.)
  • I have to see immediately what appts I have coming up (Calendar) and I have to make some phone calls (Contacts).
How'm I gonna accomplish these tasks?
BTW, I have a PC, not a Mac.
* Probably improbable, but it can't hurt to be prepared.
Richu75
Dec 6, 2012
25
Install outlook and sync it to iCloud using the 'iCloud Control Panel for Windows'.
You'll face to errors while it cannot sync at that time (or you would be able to enter the icloud website), but all your appointments and contacts will be stored locally.
iPutz
Nov 20, 2012
964
183
43
74
US Midwest
The two methods I use to see the calendar items and contact information quickly without my phone or iCloud, is:
First, is to use contact management software, such as Microsoft Outlook, on your PC and to regularly sync it with the iPhone using iTunes. Syncing would have to be done after every change in either the PC's info or the phone's, in order to keep the info the same in both.
Second, in addition to the above, have an iPad with the same information in it and keep it regularly synced with the same PC as the phone.
There are probably other methods out there but the above is the one that works for me. The biggest problem with using these two methods is if you make several changes a day, the time required to sync everything starts getting excessive.
