Quick ? About streaming Netflix
Terry M.
Feb 27, 2009
728
84
46
Des Moines, Iowa
Folks,
Don't know anyone on my physical world that might know so thought I'd ask here:
I have a 3 yr old laptop that has an old processor in it. Is it possible that could be why when streaming Netflix that it buffers all the time and slows down playback? My Internet speed via the router is fine.
Sent from my iPhone 5 using iCafe app
A three-year-old processsor should be just fine for streaming Netflix. It's more likely your internet. What are your computer specs and speedtest results on that laptop?
Terry M.
Feb 27, 2009
728
84
46
Des Moines, Iowa
I'll get that info Mindi. I should gave had it handy in my first post.
The reason I'm not sure it's my Internet is because when, on wifi, my iPhone streams it just fine ?
Thanks for the help, just new to Netflix.
Docd
Oct 16, 2011
651
62
I would for viruses and spyware as I have seen that slow stream way down.
Terry M.
Feb 27, 2009
728
84
46
Des Moines, Iowa
Here it is Mindi, please let me know your thoughts. Thank you.
http://www.cnet.com/laptops/toshiba-satellite-l455-s5000/4505-3121_7-34024547.html
Quick Specifications
See all specs
  • Processor Intel Celeron 900 / 2.2 GHz
  • Memory 3 GB / 4 GB (max)
  • Hard Drive 250 GB - Serial ATA-150 - 5400 rpm
  • Operating System Microsoft Windows 7 Home Premium 64-bit Edition
  • Display Type 15.6 in TFT active matrix
  • Max Resolution 1366 x 768 ( HD )
  • Graphics Processor Intel GMA 4500M Dynamic Video Memory Technology 5.0
  • Optical Drive DVD±RW (±R DL) / DVD-RAM
6,683
51
If Netflix is running like crap, try the following:
First, make a second user account in your PC. Then login and test Netflix. If it seems fine the first couple of times you run it, but then starts to slow or get buggy again, your system probably needs a serious cleaning.
The other possibility is if you are running anti-virus software, it could be scanning the stream and slowing it down. I know that both Nortons and McAfee are huge resource hogs, and can use more than 50% of your CPU for scanning. With a constant stream, it could be more than the system can handle if you have any other software running in the background.
One last off the wall suggestion: what browser are you using? If its Internet Exploder, try chrome or Firefox.
Docd
Oct 16, 2011
651
62
Good advice forgot about the virus protection being a resource hog.
