Quick question about themes and Summerboard
hydro94530
Jul 3, 2007
325
Hi all, I was wondering... I downloaded some themes oof Installer and I noticed some of them come with icons and not just wallpaper. I made my own wallpaper and want to make my own icons as well. Is Customize the only app I can do this with as far as getting them to work?
The reason I ask is that I don't have Customize installed, just Summerboard, and the icons, dock, and wallpaper all work through Summerboard so far. Can I grab each icon in each app and replace it with my own and will it automatically use my new ones instead? I haven't looked yet, but I assume I can go into each apps folder and drag out the .png file for the icon right? Any help is always appreciated. Thanks
hydro94530
Jul 3, 2007
325
Nice! Thanks man, I saw that app but haven't installed yet.
Scottshotz
Sep 25, 2007
318
how do you use finder. I got it and have no idea how to do anything. Is this how I fix iphysics levels and customize?
Hondamaker
May 14, 2007
9,946
671
56
Fairborn, Ohio
Can you use WinScp for that as well? Also, what .png program do you recommend to create my own icons?
You can use winscp to upload themes and icons to the iPhone, that's what I use.
BTW, I'm getting ready to play some BF2 in a few minutes!
