Quicker way to sync music to iPhone 4S through iTunes?
Goodtimekid
Jan 28, 2012
Is there an easier, quicker method of syncing music to the phone through iTunes
Sent using iCafe app
5,578
You just drag the music into iTunes and sync. Are you having problems getting it to work?
If you're asking for an alternative to iTunes, there's these:
Stock: You can use an app such as DropBox or AirSharing to drag and drop, but the music will only show up in that app; it will not show up in your iPod app.
Jailbroken: You can bypass iTunes and drag and drop music with PwnTunes. It will show up in your iPod app. It's $12.
Feb 3, 2013
190
Dragging the music to a playlist and hit sync is the easiest way :)
Goodtimekid
Jan 28, 2012
It takes an awful long time. Is it meant to backup as well during this time
5,578
Yes. The backups take longer if it's been a long time since you backed up. You can use iCloud backups instead of iTunes if it bothers you. iCloud automatically backs up once a day from the phone itself. Set it up under Settings. iTunes will no longer do it, so it will make syncing faster.
Goodtimekid
Jan 28, 2012
Thanks europa
Ill attempt it this way
