QuickPwn, Pwnage or Winpwn for 2.1 Unlock?
Andy_Panda
May 3, 2007
35
I tried QuickPwn but it does seem to be working
Do any of these actually work for an original iPhone
with firmware 2.1?
Yes, they should. Only the iPhone 3G cannot be unlocked. Are you sure you had the proper settings selected?
Andy_Panda
May 3, 2007
35
I looked at a bunch of walkthroughs and theyre all the same
But I keep coming up with the same problem.
The T-Mobile logo is on top and there are bars for signal
I can even call it and call from it if I use the Emergency
dial key pad. It just shows the USB to iTunes thing on
the front telling me to connect and that it detects a different sim
Eragon
Jan 8, 2008
3,056
50
Frederick, MD
Lincoln's right. I jailbroke and unlocked V1.1.4 using Pwnage Tools. The first time I did, I did not select the correct settings WRT the bootneuter. When you go back to customize your IPSW, pay close attention this step. I did and it worked.
Andy_Panda
May 3, 2007
35
Hmm
So your saying I should try using Pwnage
instead of QuickPwn? During QuickPwn
there is no Bootneuter
Andy_Panda
May 3, 2007
35
Ok, Im gonna restore and try it with Pwnage
thanks =]
Andy_Panda
May 3, 2007
35
OH! One last question!
When I do the unlocking, what Should I have in the Sim slot?
jimmyrules712
Sep 21, 2007
264
it shouldn't matter. I can say from experience though that you CANNOT use quickpwn to unlock the v1 iPhone. You mustu se pwnage or winpwn.
Andy_Panda
May 3, 2007
35
Ok so I used Winpwn to unlock it
But everytime I get to the restoring it
with the custom made restore winpwn
makes I get Error 1600 message.
Im following exactly every single step
I don't know what Im doing wrong
