Random Auto Restart of the iPhone
jalalawi
Apr 23, 2011
246
I am experiencing an auto restart of the phone on random basis!!!
5,578
Have you updated to 9.3.1?
5,578
Does it happen when using a specific app? If there is no pattern, I recommend restoring in iTunes if it continues.
jalalawi
Apr 23, 2011
246
No pattern as it is happening even if the phone not used!!!
5,578
First try resetting all settings through the Settings app. If that doesn't work, restoring to factory settings should fix it. You could try restoring from backup first, and then factory settings if it continues.
