Re-download Everything?
Enphekt
Jul 30, 2007
Okay to successfuly be able to remod my iPhone after the update what do I gotta redownload? and where can I find these files? thanks..
princess_80854
657
You'll need to extract the new update software into your "phonedmg" folder like you did the first time. That's it.
princess_80854
657
where can this file be found at?
Goto your Start Menu, click Run, and copy this into the Run box:
%USERPROFILE%\Application Data\Apple Computer\iTunes\iPhone Software Updates
And hit OK. A file window should pop up containing one file that starts with iPhone. Check whether it ends with ".ipsw" - if it doesn't, you'll have to turn on file extension display by going to the Tools menu -> Folder Options -> View tab -> Uncheck "Hide extensions for known file types". Right-click the iPhone update file and choose "Rename". Give it the name "iPhone.zip" and press Enter, and confirm that you want to change the extension.
Now double-click the file to open its contents. Extract them all to your modding folder overwriting the existing files.
