MacBook Pro Ready to throw my MBP out the nearest window!
Starry
Aug 13, 2009
64
Lakeway Texas
And I'm not talking Windows 7 :)
I use VMWare because some of my programs and office things require IE but for some reason I get doing something it goes to a black screen still has power but does nothing.. I have to then turn it off and restart it and all my windows are still there but it's ANNOYING!
Am I jinxed and this is only ME it's doing it too? LOL UGH
Is Parallels better than Boot Camp or is VMWare the top for Windows applications? What does anyone here who's smarter than me suggest :)
theorioles33
Jul 21, 2007
925
135
USA
Well I cant really help you figure out whats going on but I use Parallels and I have never had any issues like that. I think you can get a discount on Parallels using your VMWare license. There is also a trial and you can import your VMWare machine.
  • Like
Reactions: Starry
iphonewarrior
13,847
699
I use Parallels, it's probably the best you can get. I also have a triple-boot MBP for Win 7, Linux and obviously OS X.
Using Win 7 from a partition is very stable and really easy to set up. :)
  • Like
Reactions: Starry
Starry
Aug 13, 2009
64
Lakeway Texas
Awesome thanks... so do I need to redo my whole system to install Parallels? I'm like so not tech saavy.. I'm more like a bull in a china shop when it comes to electronics LOL :)
theorioles33
Jul 21, 2007
925
135
USA
I just checked Parallels site. You can upgrade for $29.99 from VMWare Fusion by entering your current license. Just install Parallels.
I believe you can open or import your VMWare machine in Parallels after that.
And to answer your question, all you have to do is install Parallels. Once your VM's are imported into Parallels, you can uninstall Fusion if you want.
http://www.parallels.com/products/desktop/vmwareoffer/
iphonewarrior
13,847
699
It appears my question has already been answered :)
It's fairly easy to do, if you get stuck, give one of us a shout.
Starry
Aug 13, 2009
64
Lakeway Texas
It's gonna be the one behind my head... are ya outside yet? *Grumbling* This POS! I swear I must be jinxed by electronics or something!
patrickj
Sep 2, 2007
6,221
407
Austin, Tx
ipadinsight.com
I've used VMWare and Parallels Desktop both over several years. They're both very good apps, but Parallels has been the one I've used for the last 2.5 years and it's been superb.
So I'll be another one doing my best to offer help if you have specific issues.
chris
Administrator
Administrator
Jun 10, 2006
11,817
1,707
Long Island, NY
Perfect timing on this thread. I used VMWare, but my version 3.X is not supported in Mountain Lion. Before upgrading, I was going to consider a jump to Parallels. They've both been pretty aggressive in trying to improve their products, so I've always felt they were both pretty good. Will definitely give Parallels a try and utilize my current serial to upgrade/migrate.
patrickj
Sep 2, 2007
6,221
407
Austin, Tx
ipadinsight.com
I'm betting you'll like the switch.
Starry
Aug 13, 2009
64
Lakeway Texas
I'm lost... I know I am liking this much better... but what I can't get use too is that I have my outlook and everything opening where my Mac crap is.. and I'm blonde and stupid and get confused easily! When I do something in outlook IE opens and I don't want IE to friggin OPEN I want my Chrome on the mac side to open.. *banging head on desk* I'm so stupid with this crap I could beat my son for leaving and moving to Philly there went MY tech support.. time to speed dial Tinners LMAO But HE didn't miss me.. he's saying "OH lord she's back I have to answer all these stupid questions for the broad" LOL :)~
patrickj
Sep 2, 2007
6,221
407
Austin, Tx
ipadinsight.com
Sounds like you've got it in Coherence mode. To get out of that look for the icon with two vertical red bars in the top Menu bar on your Mac. Click on it and click Exit Coherence. That should get you back to seeing your virtual machine running Windows as just another app that you can Command-Tab to.
Starry
Aug 13, 2009
64
Lakeway Texas
Which is best ? Do I want to be in the Coher.. whatever? And I did the VMWare upgrade how do I know if it really removed the VM off my computer?
patrickj
Sep 2, 2007
6,221
407
Austin, Tx
ipadinsight.com
Either one is good, it's just a matter of preference. Coherence mode is meant to make running Windows apps a more seamless sort of experience. I actually prefer the standard mode and just seeing a standard Windows 7 desktop.
To see if you still have VMWare installed just look in your /Applications folder.
