Reboot iPhone 5 if top button doesn't work
GlennS
Jul 23, 2010
My 'power' button no longer works. How can I reboot my iPhone 5 if I can't hold power and home button down at same time?
I can press the top button, but it doesn't work and all I get is Siri asking me what she can do for me (booting isn't one, I tried asking 'her'.
Mthoroughbred
Dec 16, 2008
751
102
43
I don't think you can do anything if the power button doesn't work. You might have to let the battery drain.
GlennS
Jul 23, 2010
Can an 'app' be written to do it? I can't write apps, but there are quite a few of you out there. There has to bean API since Apple update can do it.
GlennS
Jul 23, 2010
Letting battery drain is not something I want to do (though it quite frequently gets pretty close to 'drained' all on its' own)
Jun 19, 2007
33,493
4,550
Upper Marlboro, MD
If you jailbreak, you can use Activator to make pressing both volume buttons at the same time reboot your iPhone. I just tested it and it works. You'd have to jailbreak, though.
5,578
You can reboot your phone with Assistive Touch.
Settings > General > Accesibilty > Assisive Touch > On
This will place a subdued icon on the screen which can be moved anywhere you like. You can turn Assitive Touch on only when you want to reboot or you can leave it on at all times.
To reboot the phone, open Assitive Touch by tapping the icon and then click "device." Now press and hold "lock screen" for two seconds and the option for sliding to power off will appear.
Docd
Oct 16, 2011
651
66
If you turn on assistive touch in settings/general/accessibility/AssistiveTouch you. Can turn your phone off by the button on screen then device and press and hold the one that says lock screen the slide to power off will appear.
Sent from my iPad using Tapatalk
Mthoroughbred
Dec 16, 2008
751
102
43
Learn something everyday lol. Don't do what I said but what Europa said lol
GlennS
Jul 23, 2010
Well, that gets me power off - any way to reboot from there?
Mthoroughbred
Dec 16, 2008
751
102
43
Turning off the phone is another way to reboot. If you're are worried that you won't be able to turn on the phone due to the power button being busted the just plug it in and it will boot up again
Jun 19, 2007
33,493
4,550
Upper Marlboro, MD
