Redsn0w Released: iPod touch 2G Jailbroken
Since it's release, the 2nd Generation iPod touch has not been able to be jailbroken by any of the "Pwange" applications. Redsn0w, a utility announced a few weeks back by the iPhone Dev Team, however, can do the job. It was released today, and while it is a full release and not a beta version, the Dev Team cautions that it is a more complicated process than jailbreaking other Apple Mobile devices and will offer no support for it whatsoever as it is a tethered jailbreak.
Here's the thing: this jailbreak is far more complicated than any other out there. And the reason that very few people will use it until a new, universal and untethered version becomes available; it's only for the Mac and you must use a computer to turn on your iPod, every time.
From the DevTeam's Redsn0w website:
redsn0w lite
http://blog.iphone-dev.org
A no frills tethered jailbreak for iPod Touch 2G
--> YOU WILL VERY LIKELY VOID YOUR WARRANTY BY USING THIS <--
This is to be used only at your own risk.
We do not accept any responsibility for any damage that this tool may help
you cause to any of your equipment.
--> USE AT YOUR OWN RISK! <--
WE WILL BE PROVIDING ABSOLUTELY NO SUPPORT FOR THIS!
If you post comments on our blog looking for support, we reserve the
right to ban your user ID from the blog. You really shouldn't be doing
this unless you understand it all enough to not need support!
THIS IS A ***** TETHERED ***** JAILBREAK
IF YOU DON'T KNOW EXACTLY WHAT THAT MEANS, DON'T USE THIS!
There are many ways to do this. Here's one way that will probably
work for you. If it doesn't, please don't come to use for support.
We're working on an untethered version.
This is for Mac only. But you should be able to find (or work out
on your own) how to do it on Windows or Linux too.
rslite
This is an interface to the DFU and Recovery modes of the device. It
requires you to have libusb installed on your Mac.
Due to buggy interaction between libusb and the Apple device, any output
that is long gets all chewed up. But if you stick to just the "!" and
the "#" commands, you won't notice. We don't normally use this tool
but it's a lot easier to distribute and compile than the GUI we use.
The "!" (exclamation point, no quotes when you use it) sends a file.
The "#" (pound sign, no quotes when you use it) sends a script.
In both cases, you name the file right after the symbol.
Basic instructions
Note: these are the bare bones instructions. Please don't come to us
looking for more detailed instructions.
Preparation
1) Copy the FirmwareBundles and CustomPackages directories into
your PwnageTool.app/Contents/Resources directory
2) Create a custom 2.2.1 ipsw with PwnageTool in Advanced mode. Don't
enable custom boot logos.
3) From your custom 2.2.1 ipsw, extract these (patched) files:
iBSS.n72ap.RELEASE.dfu (name it iBSS221pwn.dfu)
iBoot.n72ap.RELEASE.img3 (name it iBoot221pwn.img3)
4) From the official 2.1.1 ipsw, extract this (unpatched) file:
iBSS.n72ap.RELEASE.dfu (name it iBSS211.dfu)
Installing the jailbroken custom ipsw
5) Put your ipt2g into DFU mode using keypresses. Don't have iTunes running!
6) Start rslite. Send the official iBSS from 2.1.1: !iBSS211.dfu
7) Start rslite again. Send the redsn0w-lite patch: #pwn211ibss.txt
8) Send the patched iBSS from 2.2.1: !iBSS221pwn.dfu
9) Use iTunes to do a full restore using your custom 2.2.1 ipsw
Tethered boot
After the install, your ipt2g will not be bootable without assistance
from a tethered computer. The method in this README.txt requires you
to go into DFU mode, but you should be able to find (or work out on
your own) other more convenient ways.
10) Repeat steps 5-8
11) Send the patched iBoot from 2.2.1: !iBoot221pwn.img3
Your homescreen should soon show up. You can then start iTunes.
PepeRB29
Mar 21, 2008
1,500
8 mile
damn, interesting. good lookin out lincoln. i just bought my friend a 32gb ipod touch 2nd gen for when he deploys to afghanistan and would love to jailbreak it for him before he goes, however i don't think i will be attempting this until i hear some reviews.
Ezekiel2517
Sep 20, 2007
693
ive heard of this.... doesn't sound to useful with you having to boot up your ipod with your computer... what if youre out somewhere and you have to reboot it or something? doesn't sound like a situation id like to be in.
i think ill wait for the next version...
kadeschs
Jan 16, 2009
Yeah, that wouldn't be fun. However, I can't think of an instant where I've had to reboot my iPod. Not sure how often I've even shut it off completely for that matter.
