Reduce Motion Option in iOS 7.0.3 Does Just That
chris
Administrator
Administrator
Jun 10, 2006
11,812
1,778
Long Island, NY
I have Reduce Motion on and updated to iOS 7.0.3. It really removes any sort of animation. It's kind of bizarre. In iOS 6, there seems to be more animation than with this option turned on. I'm not sure if it's the combination of the super-speedy A7 processor, but it sort of feels like apps fade in and out, like I've used an iMove transition.
Have you tried it?
Rafagon
Dec 7, 2011
7,566
1,252
44
Miami, Florida
Have you tried it?
Wow, you know what? When I updated to 7.0.3 today, I decided to treat myself (i.e. throw caution to the wind and use extra battery for eye candy, even if only for a few days) by setting Reduce Motion to OFF (I had pretty much had it set to ON for as long as I can remember, since I prefer longevity of battery charge over eye candy).
However, I tried what you suggested above, and I really like the results. It's even more eye-candy'ish than with the Reduce Motion set to OFF, IMHO.
I really dig these silky-smooth fades from screen to screen and will probably keep it this way for a few days.
radtechy
Jul 20, 2011
496
41
Just to get this straight. Reduce motion set to ON with 7.0.3 takes away the animation. Yes or no answer please.
Also I didn't update to 7.0.2 on my 5s cause the battery life is so good with the 7.0.1 I'm afraid of messing up a good thing. You know if its not brokers don't fix it
Sent from my iPhone 5S using Tapatalk
chris
Administrator
Administrator
Jun 10, 2006
11,812
1,778
Long Island, NY
Yes. Setting 'Reduce Motion' to 'On' (green) removes the animation. Opening apps and switching creates almost an iMovie like transition.
