Reinstalling Leopard on MBP and connecting iPhone
xmarkzdasp0t
Dec 25, 2007
33
I plan on reinstalling leopard onto my macbook pro, erasing everything and reinstalling. will I have a problem after i reinstall leopard and i plug my iPhone into my computer?
15,385
1,089
if you try to sync any media, it will be erased from your iPhone. if you want your phone to load your contacts into OSX, then sync and when it asks you what to do with your contacts, tell it to "merge" instead of replace. Again, if you want to keep your music/videos/pics on your phone, be sure to uncheck all of those from syncing before you do this.
xmarkzdasp0t
Dec 25, 2007
33
ok cool thanks..
just wanted to make sure it wouldn't erase my contacts and things like that.
15,385
1,089
as long as you choose "merge", your contacts will be loaded back onto the computer from your iPhone.
