Relocking of iPhone 3GS iOS 5.0.1iPad baseband
enjoylife1788
Jan 7, 2011
186
Hey guys,
I have an iPhone 3GS on iOS 5.0.1. Recently I had to travel to another country and thus unlocked it with the iPad baseband. Now the issue is I am back to my home country and am facing battery issues and gps being broken on iPad baseband.
So is it possible to relock the iPhone 3GS?
I have shsh blobs of iOS 4.1 and 6.0.1. Never saved earlier as never had the need to jailbreak earlier.
enjoylife1788
Jan 7, 2011
186
So whats the best way for me to get my phone jailed? I do the downgrade as told and then can I restore?
iphonewarrior
13,847
699
I'm not 100% sure to be honest, you can obviously perform the downgrade (baseband) then jailbreak anyway your current iOS. You'll need SHSH blobs for firmware if you want to restore to an older iOS. If you downgrade and restore to iOS 6.x.x then you'll have a tethered jailbreak.
enjoylife1788
Jan 7, 2011
186
Even I am in the same dilemma.. But eventually this time I don't care about the jailbreak.. I am ok with a jailed device too.. All I care is to rectify the battery issues along with GPS.. I don't do much on 3GS as its old tech now..
So can't I just downgrade the baseband and then directly restore to iOS 6.0.1?
iphonewarrior
13,847
699
Yes, of course you can. I'd downgrade, then I'd restore to 6.0.1.
Sent using iCafe app
