MacBook Pro Remote connection Apple-PC
the panda
Jan 17, 2012
Hi there.
Is it possible to control Win7 PC with Macbook pro over the internet, and how? I'm sure some of ye should have the same problem.
Panda
Lon
Jun 5, 2010
2,946
132
Alaska
Hi there.
Panda
Yes. There are a lot of programs out there, including LogMeIn and GoToMyPC and many others.
iphonewarrior
13,847
699
You can use TeamViewer or LogMeIn, both of these are free. If you have an iDevice i.e iPhone you can control either a Mac or PC via your phone, through their respective apps. I use TeamViewer daily to login into my colleagues work laptops when they get stuck with stuff.
Another route to consider is a VNC client for both machines. I also use VNC Viewer to log into my server, via VPN (more secure than your typical RDP).
